January 24, 200818 yr comment_1563 We were asked this question recently: I have two tanks that need sealing, one has mild rust and dirt but the other is in bad condition. Both are 3 gallon Honda 450 tanks. Would one large kit be able to do both tanks? Link to comment https://success.kbs-coatings.com/topic/932-two-gas-tanks/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
February 27, 201313 yr Author comment_2636 Yes that should handle both. I would recommend cleaning and prepping both at the same time, then after allowing the tanks to dry COMPLETELY, open the sealer and stir. Then pour half into each tank. You cannot pour the whole pint into one tank, then roll it around, then pour the remaining sealer into the other tank. The sealer will be too far along in its' cure to work correctly. Check out the Tank Sealer Directions here: http://www.kbs-coatings.com/tank-sealer-directions.html Link to comment https://success.kbs-coatings.com/topic/932-two-gas-tanks/#findComment-2636 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
