January 17, 200818 yr comment_1517 Got a heavy buildup of algae & slime on my boat. Will KBS Klean work to remove it? Link to comment https://success.kbs-coatings.com/topic/886-clean-boat/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
February 19, 201511 yr Author comment_3124 Yes, KBS Klean will remove algae and slime on a boat. KBS Klean can even be run through your pressure washer for convenience. KBS Klean directions can be found HERE. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/886-clean-boat/#findComment-3124 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 7, 20206 yr comment_5250 I am looking to use your KBS clean on my old gelcoat prior to your Diamond Coat. I expect I will get some drippage down sides onto the copolymer bottom paint that has antifouling components in it. Is there going to be a problem with the cleaner shutting down my bottom paint effectiveness ? Link to comment https://success.kbs-coatings.com/topic/886-clean-boat/#findComment-5250 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 9, 20206 yr Author comment_5253 This should not be a problem. Mix KBS Klean and hot water (1 to 1) in a bucket. Dip a scotch brite pad in the KBS Klean solution and scrub the gelcoat. Then take a sponge dipped in clean water and wipe down/rinse the surface. If some of the KBS Klean solution drips on the anitfouling paint, that not compromise that finish. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/886-clean-boat/#findComment-5253 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
