January 10, 200818 yr comment_1462 We are currently doing a tear down and rebuild of several CNC machines at my workplace. Most of the machine parts will be sent out for sandblasting and painting using your RustSeal. Some of the larger pieces will be painted in-house. Our maintenance area where the painting will occur is not the most remote area of the plant and people are working in the near vicinity. What kind of fumes does the RustSeal emit and how intense are they? Do we need any Personal Protection Equipment when working with the prep chemicals or RustSeal? We will be using brushes and rollers to apply the RustSeal. Also, do we need to topcoat the RustSeal or will it be fine by itself? Link to comment https://success.kbs-coatings.com/topic/831-cnc-machines/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
March 1, 201313 yr comment_2649 If you are not spraying but are applying by brush or roller, you should be wearing gloves and eye protection. If it is an enclosed area (like a building) you should have moving air around the job area ... fans, open doors etc. Care should always be taken to minimize the exposure to solvents. Most of the solvents are released within the first 2 hours. After that there is minimal release. Yes, PPE should be worn as per directions and cautions on the labels. As your CNC machines are inside the RustSeal will be fine as long as you are happy with the color. Check out the complete directions for RustSeal here:Â http://www.kbs-coatings.com/rustseal-directions.html Please let us know if you have additional questions. Link to comment https://success.kbs-coatings.com/topic/831-cnc-machines/#findComment-2649 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
