wood w/ gesso,acrylic, watercolor paints. can this seal without bleeding?
GOLDEN Artist Colors suggested I contact you about DiamondFinish Clear for a painted wooden shield.
The shield is constructed from poplar, prepared with three layers of acrylic gesso, and painted primarily with acrylic paint. Some watercolor was used beneath the acrylic, and that watercolor has previously caused bleeding when overpainted.
I'm looking for a permanent, exceptionally clear, non-yellowing, scratch-resistant gloss finish. The shield will be handled and subjected to occasional bumps and scrapes, but not struck with metal weapons.
Could you advise:
  1. Can DiamondFinish Clear be applied directly over fully cured acrylic paint on acrylic gesso?
  2. Are its solvents likely to disturb watercolor pigment beneath the acrylic, including areas where the watercolor may not be completely isolated?
  3. Would you recommend a compatible spray sealer before DiamondFinish, or direct application?
  4. Can the product be brushed without disturbing the artwork?
  5. Is sanding required for adhesion over painted artwork? I cannot sand the original design.
  6. Does the cured coating provide UV protection for underlying pigments, in addition to being UV-stable itself?
I'd prefer to avoid experimental combinations of incompatible coatings because the artwork is irreplaceable.
Thank you!
Hi SirBadger,
Thanks for laying out every layer of the shield. Here are answers in the order you asked.
  1. Yes, DiamondFinish Clear goes directly over fully cured water-based acrylic paint. "Fully cured" means the full cure time on the paint maker's data sheet, not dry to the touch. Water-based acrylics feel dry long before they are cured, and clearing them too soon is a common mistake that can lead to cracking under the clear.
  2. DiamondFinish Clear contains no water. It is a solvent-borne, moisture-cured urethane, and it is reduced only with KBS #1 Thinner or xylene. We have not tested it over watercolor, so we can't promise how watercolor pigment will react where the acrylic doesn't fully cover it. That is the reason for the test board described below.
  3. Apply it directly. No isolation coat or separate sealer is needed over cured acrylic, and leaving out a third product avoids the kind of untested combination you want to stay away from.
  4. Yes, it brushes well. Brushed on in thin coats, it flows out on its own as it cures. A bristle or foam brush works, and a poly bristle brush gives the nicest finish. Lay each coat on and leave it alone rather than working it back and forth. Apply a minimum of two thin coats, recoating once the previous coat is dry to the touch and leaves no fingerprint, typically within 2 to 4 hours.
  5. No sanding is needed on your shield. The standard 600 to 1200 grit scuff is for older finishes that have aged or picked up contamination. A fully cured acrylic painting that has been kept clean can be coated without sanding.
  6. DiamondFinish Clear is UV stable itself: it went through 1000 hours of QUV 313B accelerated weathering with no yellowing or chalking. It contains UV absorbers, which cut down the UV reaching the paint underneath. Those absorbers wear down with sun exposure, though, so it does not block UV completely or permanently. Lightfast pigments in the paint remain the main defense against fading.
For the handling and bumps you described, DiamondFinish Clear can be handled after 1 day and reaches 7H pencil hardness at 7 days, then keeps hardening for weeks. DiamondFinish Clear comes in high gloss.
Because the shield is irreplaceable, we strongly suggest a test board first. Take a scrap of poplar and build the same layers: acrylic gesso, watercolor, then acrylic, including a spot where the watercolor is only thinly covered. Let it cure as long as the shield has, then run the full process on it. Our standard prep wash is KBS Klean diluted 10 parts hot water to 1 part KBS Klean, then a rinse and complete drying. Since water is what reactivated your watercolor before, try that wash on the test board's thin spot too. If the test board comes through clean, you'll know what to expect on the shield.
Before you get started, we strongly recommend reading through the complete application directions. The links are included below. The answers above are a quick orientation, not a substitute for the full directions.
If anything comes up on the test board or along the way, post it here and we'll help you sort it out.
  • Author
Thank you so much! The frustrating part is that the watercolor was an accident, it was supposed to be only acrylic. Test Board it is!
