July 5Jul 5 comment_10507 Will Rust Seal stick to SS rivet heads without sanding as they would be hard to get to? Link to comment https://success.kbs-coatings.com/topic/7663-rust-seal-and-stainless-steel/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 17Oct 17 comment_10529 You can skip the sanding. As long as you clean the rivet heads with KBS Klean and then etch them with RustBlast, RustSeal will bond and bite well to the stainless steel. Here is the process:Clean the rivet heads with KBS Klean. Rinse thoroughly with water before it dries, then let them dry completely.Apply RustBlast full strength and keep the surface wet for a minimum of 30 minutes, re-applying as needed so it never dries.Rinse thoroughly with water before the RustBlast dries, then let the rivets dry completely. A slight white powder left behind is zinc phosphate, and it helps RustSeal adhere, so leave it in place.Apply RustSeal in thin coats, a minimum of 2 coats at 2 mils each, with 2 to 6 hours between coats.Before you get started, we strongly recommend reading through the complete application directions for each product. The links are included below. The steps above are a quick orientation, not a substitute for the full directions.RustSealRustSeal Application DirectionsRustBlastRustBlast Application DirectionsKBS KleanIf you have any other questions as you work through the project, reply here and we'll be glad to help. Link to comment https://success.kbs-coatings.com/topic/7663-rust-seal-and-stainless-steel/#findComment-10529 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
