April 27, 20251 yr comment_9729 is it ok to use the kbs maxx clear coat over the maxx hotrod black , if applied within the normal recoat timeframe ? im wanting to use the black on a motorcycle gas tank , then apply decals , then clear with satin over them Link to comment https://success.kbs-coatings.com/topic/7036-kbs-maxx-hot-rod-black/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
April 28, 20251 yr comment_9735 Yes, you can absolutely apply KBS MAXX Clear over KBS MAXX. Applying KBS MAXX, then decals, and then clearing the whole surface with KBS MAXX Clear is the way to go. KBS MAXX Clear is also very chemically resistant making it ideal for a gas tank. Please check out the KBS MAXX Clear application directions -> https://www.kbs-coatings.com/kbs-maxx-clear-directions Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/7036-kbs-maxx-hot-rod-black/#findComment-9735 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
