April 15, 20241 yr comment_5680 About to seal the tank for my 2006 GSXR750 but the shape of the tank does not have any opening at low spots so I can’t drain the excess by just having it pour out. For the cleaner and acid I was able to siphon out whatever I couldn’t dump out but the sealer is too thick for a siphon. Any suggestions? Link to comment https://success.kbs-coatings.com/topic/3090-how-to-drain-excess-tank-sealer/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
April 15, 20241 yr comment_5681 In general, most that have tanks like this (where draining is very difficult or impossible) will use clean shop rags to dab up the excess Tank Sealer. You can then let the rags harden up and throw them away. Please be sure to check out the Complete Tank Sealer Directions: https://www.kbs-coatings.com/tank-sealer-directions.html Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/3090-how-to-drain-excess-tank-sealer/#findComment-5681 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
