KBS Coatings Posted November 24, 2025 Report Share Posted November 24, 2025 Are you looking to coat the inside of the tank or the outside of the tank? Where is the powdercoating? Outside of the tank? Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/page/2/#findComment-10128 Share on other sites More sharing options...
Odyknuck Posted November 24, 2025 Report Share Posted November 24, 2025 Its powder coated inside and out. I'm looking only to seal the seams at the bottom where the tank joins the base plate. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/page/2/#findComment-10129 Share on other sites More sharing options...
KBS Coatings Posted November 25, 2025 Report Share Posted November 25, 2025 For a powder coated surface, lightly scuff with 300 grit and then clean well with KBS Klean, rinse, and let dry. Then apply RustSeal. Always thin coats and at least two coats. RustSeal Application Directions -> https://www.kbs-coatings.com/rustseal-directions Please reach back out with any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/page/2/#findComment-10130 Share on other sites More sharing options...
Odyknuck Posted November 25, 2025 Report Share Posted November 25, 2025 Hmm, Rust seal over tank sealer. Please clarify why this product is better for this application over tank sealant I used on the first tender. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/page/2/#findComment-10131 Share on other sites More sharing options...
KBS Coatings Posted November 25, 2025 Report Share Posted November 25, 2025 Because you are looking to "seal the seams at the bottom" of the exterior of the tank, we recommend RustSeal because it is designed to be brushed on versus Tank Sealer, which is formulated to be rolled around and drained from the inside of a tank (where it is not feasible to brush). Tank Sealer and RustSeal are the same base formulation with the main differences being pigment load and viscosity. RustSeal is more heavily loaded with pigments and Tank Sealer is thinner making Tank Sealer perform better for applications inside a tank. Based upon that, what other questions might you have? Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/page/2/#findComment-10133 Share on other sites More sharing options...
Odyknuck Posted November 25, 2025 Report Share Posted November 25, 2025 Ok, actually its the inside of the tank I would be sealing the seams. Refer to page one of the thread to get a better ideal of what I am talking about. Also note there there will be non coated SS rivets at the seam. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/page/2/#findComment-10134 Share on other sites More sharing options...
KBS Coatings Posted November 25, 2025 Report Share Posted November 25, 2025 For the inside of a tank, you will use Tank Sealer. Tank Sealer Directions -> https://www.kbs-coatings.com/tank-sealer-directions What other questions might you have. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/page/2/#findComment-10135 Share on other sites More sharing options...
Odyknuck Posted November 25, 2025 Report Share Posted November 25, 2025 So do I still need too sand the seams with the sealer. Also because I am just doing the seams inside, will the rust seal also work? Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/page/2/#findComment-10136 Share on other sites More sharing options...
KBS Coatings Posted November 25, 2025 Report Share Posted November 25, 2025 Yes, for a powder coated seam surface, lightly scuff with 300 grit and then clean well with KBS Klean, rinse, and let dry. Yes, if the coating is being brushed, RustSeal will work great for the seams inside. What other questions might you have? Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/page/2/#findComment-10137 Share on other sites More sharing options...
Odyknuck Posted November 26, 2025 Report Share Posted November 26, 2025 Just too confirm the tank will be filled with water when in use? How long between coats do I wait? Does it matter what color I use as safety blue would allow me to see where I apply it better than black? an I just use denatured alcohol acetone to clean the seams prior to application? Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/page/2/#findComment-10140 Share on other sites More sharing options...
KBS Coatings Posted November 26, 2025 Report Share Posted November 26, 2025 Quote Just too confirm the tank will be filled with water when in use? Yes, that is what you have stated and we have considered this in all of our answers. Quote How long between coats do I wait? Re-coating RustSeal can be done once the first or consecutive coat is dry-to-touch and does not leave a fingerprint which is typically within 2-6 hours depending on temperature and humidity. This timeframe may be longer on the inside of a tank because of the lack of airflow. Quote Does it matter what color I use as safety blue would allow me to see where I apply it better than black? RustSeal color does not matter. Quote an I just use denatured alcohol acetone to clean the seams prior to application? This is NOT recommended and discouraged. RustSeal Complete Directions -> https://www.kbs-coatings.com/rustseal-directions Please reach back out with additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/page/2/#findComment-10141 Share on other sites More sharing options...
Odyknuck Posted November 30, 2025 Report Share Posted November 30, 2025 Can any other grit sand paper be used? I have 220 and 400, no 300. How big of a gap can rust seal fill? Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/page/2/#findComment-10149 Share on other sites More sharing options...
KBS Coatings Posted November 30, 2025 Report Share Posted November 30, 2025 4 hours ago, Odyknuck said: Can any other grit sand paper be used? I have 220 and 400, no 300. How big of a gap can rust seal fill? Yes, 220 or 400 will absolutely get the job done. RustSeal cures to .002" (2 mils) per coat which is the size gap RustSeal filles. Always apply RustSeal in THIN coats and never medium or heavy coats. That is key. Please reach back out with additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/page/2/#findComment-10150 Share on other sites More sharing options...
