Jim P Posted December 12, 2023 Report Share Posted December 12, 2023 Using the three step kit for the second time. Hopefully as successful as the first. Question is how long should it cure before adding fuel. Ethanol free gas. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/ Share on other sites More sharing options...
KBS Coatings Posted December 13, 2023 Report Share Posted December 13, 2023 When using the KBS Tank Sealer System, allow your tank to air-dry naturally in a well-ventilated area. Allow 96 hours for maximum cure. If applicable, always test the tank with water before re-filling with fuel. Please review the complete Tank Sealer Directions and let us know if you have any additional questions. Jim P 1 Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-5644 Share on other sites More sharing options...
Odyknuck Posted September 15, 2025 Report Share Posted September 15, 2025 My application is for a 1 1/2" scale locomotive tender that only holds water. It is an open top tank so can the cure time be less? I will be brushing the sealer on. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9945 Share on other sites More sharing options...
KBS Coatings Posted September 16, 2025 Report Share Posted September 16, 2025 15 hours ago, Odyknuck said: My application is for a 1 1/2" scale locomotive tender that only holds water. It is an open top tank so can the cure time be less? I will be brushing the sealer on. Yes, with the better air flow that comes from an open top, the cure time for Tank Sealer will be less. Please review the complete Tank Sealer Directions and let us know if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9946 Share on other sites More sharing options...
Odyknuck Posted September 16, 2025 Report Share Posted September 16, 2025 So by how much as I am on a time constraint on this project and unfortunately this project was unforeseen. It only holds water so I would not think cure time would be as needed for fuels. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9947 Share on other sites More sharing options...
KBS Coatings Posted September 16, 2025 Report Share Posted September 16, 2025 We have not tested a tank with only three sides as this is not a standard application. For one side, it is 24-48 hours full cure time. Obviously, one side has more air flow than three sides. We understand you would like a precise answer, but we have not tested your specific application and there are quite a few variables leaving us unable to give you a precise answer. Once the Tank Sealer is set up (no longer moving), add air flow and humidity. We know for a fact that will speed the cure time. Please reach out with any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9948 Share on other sites More sharing options...
Odyknuck Posted September 17, 2025 Report Share Posted September 17, 2025 Ok thanks for the input, my next question that working with an open tank there is no real good way to pour the liquids into the tank and roll it around. So what tips do you have on how to proceed? Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9949 Share on other sites More sharing options...
Odyknuck Posted September 17, 2025 Report Share Posted September 17, 2025 Forgot to mention the tank is riveted to the base plate and will leak thru the seams. It is already painted/powder coated on the outside. I have been sand blasting the rust off etc so I am also concerned about flash rust. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9950 Share on other sites More sharing options...
KBS Coatings Posted September 17, 2025 Report Share Posted September 17, 2025 9 hours ago, Odyknuck said: Ok thanks for the input, my next question that working with an open tank there is no real good way to pour the liquids into the tank and roll it around. So what tips do you have on how to proceed? Tank Sealer and RustSeal are very similar products. The main difference is less pigmentation and slightly more viscous. So, apply Tank Sealer as you would RustSeal when brushing it on. Thin, covering coats. Minimum of two coats. Re-coating can be done once the first or consecutive coat is dry-to-touch and does not leave a fingerprint which is typically within 2-6 hours depending on temperature and humidity. If spraying, clean your spray gun immediately after using RustSeal. +RustSeal Directions Please reach out with any additional questions. 4 hours ago, Odyknuck said: Forgot to mention the tank is riveted to the base plate and will leak thru the seams. It is already painted/powder coated on the outside. I have been sand blasting the rust off etc so I am also concerned about flash rust. Newly sandblasted (fresh and not recycled sand) metal surfaces that have been handled with gloved hands are the ideal choice for direct RustSeal applications as they require no preparation other than blowing off loose dust. +RustSeal Directions Please reach out with any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9951 Share on other sites More sharing options...
Odyknuck Posted September 17, 2025 Report Share Posted September 17, 2025 That is really good to know as it helps a lot in my application. Thanks much KBS Coatings 1 Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9952 Share on other sites More sharing options...
Odyknuck Posted September 18, 2025 Report Share Posted September 18, 2025 So, I am having a hard time getting all the rust from inside the tank as its very tight in areas the sand blast gun can not be in a good position. There is no loose rust, just imbedded. I could brush on some of the prep on that helps. How forgiving is the sealer on this? Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9954 Share on other sites More sharing options...
KBS Coatings Posted September 18, 2025 Report Share Posted September 18, 2025 Yes, apply the KBS Klean and RustBlast with a sponge and also do the rinsing with a sponge. That is the easiest way to do that with a tank like you have. Doing the prep (KBS Klean and RustBlast) would enhance adhesion, absolutely. Please reach out with any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9955 Share on other sites More sharing options...
Odyknuck Posted September 18, 2025 Report Share Posted September 18, 2025 Thank you as I have way to many hours into this project already! KBS Coatings 1 Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9956 Share on other sites More sharing options...
Odyknuck Posted September 18, 2025 Report Share Posted September 18, 2025 So I finished the clean and etching steps and while drying it bflash rusted a lot, please advise. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9957 Share on other sites More sharing options...
KBS Coatings Posted September 19, 2025 Report Share Posted September 19, 2025 3 hours ago, Odyknuck said: So I finished the clean and etching steps and while drying it bflash rusted a lot, please advise. Yes, that looks quite normal. A very nice dusting of zinc phosphate which enhances the adhesion of the Tank Sealer. Please reach out with any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9958 Share on other sites More sharing options...
Odyknuck Posted September 19, 2025 Report Share Posted September 19, 2025 Ok, cool I will apply the sealer tomorrow, Thanks again KBS Coatings 1 Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9959 Share on other sites More sharing options...
Odyknuck Posted September 19, 2025 Report Share Posted September 19, 2025 How do I know when the sealer is completely cured? Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9961 Share on other sites More sharing options...
KBS Coatings Posted September 19, 2025 Report Share Posted September 19, 2025 We tested full cure in our lab and then give that information on the directions. Cure is very dependent on temperature, humidity, and air flow. For your non-standard application, our best advice is to add a fan (air flow) after the final coat of Tank Sealer is dry to touch and then full cure should be reached at 24 hours (taking that from the RustSeal Directions). Please reach out with any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9963 Share on other sites More sharing options...
Odyknuck Posted September 19, 2025 Report Share Posted September 19, 2025 Its 70% humidity in the shop, is this too high? Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9964 Share on other sites More sharing options...
KBS Coatings Posted September 19, 2025 Report Share Posted September 19, 2025 70% is fine for humidity. Please reach out with any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9965 Share on other sites More sharing options...
Odyknuck Posted September 19, 2025 Report Share Posted September 19, 2025 It dropped to low 60%s after I closed up the shop. I ended up pouring the can in and applied like a regular tank however I did not drain enough out and had air bubbles. I slit them with a razor blade and used a steel roller to deflate them as best I could, we shall see! Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9966 Share on other sites More sharing options...
Odyknuck Posted September 20, 2025 Report Share Posted September 20, 2025 Just throwing this out there. A lot of guys use bed liner to seal these tanks and it works well. Considering the current air bubble situation I have would it be prudent to spray a layer of it over the bottom only? Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9969 Share on other sites More sharing options...
KBS Coatings Posted September 20, 2025 Report Share Posted September 20, 2025 Quote Considering the current air bubble situation I have would it be prudent to spray a layer of it over the bottom only? Sure. No problem with that. Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9971 Share on other sites More sharing options...
Odyknuck Posted September 20, 2025 Report Share Posted September 20, 2025 Cool, I will probably do that as an extra layer of leak protection. Thanks Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-9972 Share on other sites More sharing options...
Odyknuck Posted November 24, 2025 Report Share Posted November 24, 2025 So I have another tender to seal. This time its a brand new one that has been Powder Coated. Will the sealer stick too it? Quote Link to comment https://success.kbs-coatings.com/topic/3068-cure-time/#findComment-10127 Share on other sites More sharing options...
