December 11, 20232 yr comment_5640 I need to seal up some seams after welding in my patch panels in my floor. I plan to use RustSeal to encapsulate the entire area before applying any seam sealer. Is there a seam sealer (either brand or type) that you recommend which will work well with RustSeal? Link to comment https://success.kbs-coatings.com/topic/3067-seam-sealer-question/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 11, 20232 yr comment_5642 Many of our customer really like TigerSeal, but if you have a seam sealer that you like, feel free to use it. Simply lightly scuff the section of RustSeal where the seam sealer will adhere and that will give you an incredible bond. The RustSeal will provide the rust protection and the seam sealer will give it the finished look. Please let us know if that helps and do not hesitate to reach out if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/3067-seam-sealer-question/#findComment-5642 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
