October 9, 20224 yr comment_5570 There are two different specifications for air guns, PSI and airflow. I need to know the minimum requirements to use your KBS air gun. I am trying to use the cavity coater but the gun will not spray the stuff out at all. I have a little compressor that will go up to 120PSI but it may not flow enough air, thus the question above. Link to comment https://success.kbs-coatings.com/topic/3025-kbs-gun-air-requirements-needed/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 10, 20224 yr comment_5571 For the KBS Schutz Gun: Air Flow Consumption: 6.5 SCFM (with extension probe). Please reach out if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/3025-kbs-gun-air-requirements-needed/#findComment-5571 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
