May 31, 20224 yr comment_5488 What is the best way to keep panels wet while I’m working underneath a car? The car is on tall jack stands and I’m on my back. The time isn’t an issue but how do I keep the RustBlast applied without dripping off? Would the Rust Converter spray be a better option? Link to comment https://success.kbs-coatings.com/topic/2997-treating-underside-of-a-car/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 31, 20224 yr comment_5489 You want to reapply the RustBlast as often as necessary so the surface does not dry. Most people will put a tarp down (RustBlast will drip) and spray RustBlast from an offset position so the RustBlast does not drip down onto their person. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2997-treating-underside-of-a-car/#findComment-5489 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 31, 20224 yr Author comment_5490 I was thinking of using a soaked sponge as the applicator. Instead of a spray that will inevitably drip. Link to comment https://success.kbs-coatings.com/topic/2997-treating-underside-of-a-car/#findComment-5490 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 31, 20224 yr comment_5491 Yes, you can use a sponge soaked in RustBlast. Please be sure you wear gloves during the application. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2997-treating-underside-of-a-car/#findComment-5491 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
