Jason Kendall Posted April 26, 2022 Report Share Posted April 26, 2022 I just bought the complete all in one chassis coating system and plan to use the system to protect my rocker panels. I have surface rust starting under the undercoating in places. I plan to try to remove as much as the undercoating before applying the system. My question is, is it ok to scuff up the undercoating that properly adhered and apply over rather than trying to remove every bit? Quote Link to comment https://success.kbs-coatings.com/topic/2988-question-on-prep-for-existing-undercoating/ Share on other sites More sharing options...
KBS Coatings Posted April 27, 2022 Report Share Posted April 27, 2022 Yes, is it perfectly fine to scuff up the undercoating that properly adhered, clean with KBS Klean, and apply RustSeal and BlackTop. If you do have any bare or rusty spots/areas, please etch those with RustBlast before RustSeal and BlackTop. Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/2988-question-on-prep-for-existing-undercoating/#findComment-5469 Share on other sites More sharing options...
Jason Kendall Posted April 27, 2022 Author Report Share Posted April 27, 2022 3 minutes ago, KBS Coatings said: Yes, is it perfectly fine to scuff up the undercoating that properly adhered, clean with KBS Klean, and apply RustSeal and BlackTop. If you do have any bare or rusty spots/areas, please etch those with RustBlast before RustSeal and BlackTop. Please let us know if that helps and if you have any additional questions. Thank you! KBS Coatings 1 Quote Link to comment https://success.kbs-coatings.com/topic/2988-question-on-prep-for-existing-undercoating/#findComment-5470 Share on other sites More sharing options...
