August 5, 20215 yr comment_5339 Which of your coatings should I use to seal the inside of an Aluminum Tank I use as my 100% Methanol Fuel Reservoir on my Injection System? Also, are there any special instructions or suggestions on prep and coating maintenance/reapplication beyond those already provided on your site/products? Thanks in Advance Link to comment https://success.kbs-coatings.com/topic/2943-aluminum-tank-for-100-methanol/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 6, 20215 yr comment_5340 Does the tank have a previous coating or is it bare aluminum? Link to comment https://success.kbs-coatings.com/topic/2943-aluminum-tank-for-100-methanol/#findComment-5340 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 8, 20215 yr Author comment_5341 It's bare aluminum with light oxidation. Link to comment https://success.kbs-coatings.com/topic/2943-aluminum-tank-for-100-methanol/#findComment-5341 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 9, 20215 yr comment_5342 Prepping a bare aluminum tank is the same process as prepping a bare steel tank. RustBlast will etch the aluminum. 100% Methanol is no problem at all for Tank Sealer. Please be sure to follow the Tank Sealer Directions and let us know if you have any questions. Link to comment https://success.kbs-coatings.com/topic/2943-aluminum-tank-for-100-methanol/#findComment-5342 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 4, 20215 yr Author comment_5362 Thank you 👍🏻😎 Link to comment https://success.kbs-coatings.com/topic/2943-aluminum-tank-for-100-methanol/#findComment-5362 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
