July 24, 20215 yr comment_5330 Fusion is hardly compatible with the Top coater aerosol, is there a way to avoid sanding and etch directly into Top coater to apply additional layers ? Link to comment https://success.kbs-coatings.com/topic/2939-etching-top-coater/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
July 26, 20215 yr comment_5333 For KBS Top Coater Aerosol, recoating can be done once first or consecutive coat is dry-to-touch. For best results, always apply KBS Top Coater coats consecutively within 24 hours of each coat curing. There is no reason to use Fusion SEP when applying additional coats of KBS Top Coater Aerosol. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2939-etching-top-coater/#findComment-5333 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
