October 24, 20206 yr comment_5238 I have a 20 year old Hilux diesel ute. There are two main areas of rust as well as a few specs in the otherwise shiny tank. The rust found its way into the fuel filters, causing reliability problems. The tank was cleaned out and the filters replaced, but as the rust still flakes off, if the fuel gets very low, the filters suck it up and the problem resurfaces. Here is a photo of the inside of the tank, showing the two main areas. Will the sealer system cover this much rust, or is it only for small patches? Link to comment https://success.kbs-coatings.com/topic/2903-will-the-kbs-tank-sealer-system-fix-this-rust-problem/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 24, 20206 yr comment_5240 Yes, the KBS 3 Step Tank Sealer System is absolutely ideal for a 20 year old diesel tank. It will clean and prep the entire inside of the tank and then seal up the entire inside of the tank including the already rusty areas. The KBS 3 Step Tank Sealer System will deal with the current rust spots and make sure you do not develop any rust spots in the future. How many gallons does you tank hold? Link to comment https://success.kbs-coatings.com/topic/2903-will-the-kbs-tank-sealer-system-fix-this-rust-problem/#findComment-5240 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 24, 20206 yr Author comment_5241 70 litres. Oh, oops, I just noticed that you are in the US - gallons. I am in Australia. Unless your product is already distributed in Australia, that will be a problem. Nothing from the US is coming into Australia at the moment due to COVID. We are pretty much locked off from the rest of the world at the moment. Very few cases. Almost nobody allowed in or out of the country. You can do that when you're an island. Even the biggest one. 😞 Link to comment https://success.kbs-coatings.com/topic/2903-will-the-kbs-tank-sealer-system-fix-this-rust-problem/#findComment-5241 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 26, 20206 yr comment_5243 For clarification: We are not affiliated in any way with KBS Coatings in Australia. Please feel free to contact KBS Coatings Australia for any support on their products that you might need here: http://www.kbs-coatings.com.au/contact-us/ Link to comment https://success.kbs-coatings.com/topic/2903-will-the-kbs-tank-sealer-system-fix-this-rust-problem/#findComment-5243 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
