August 4, 20206 yr comment_5172 I painted a couple of parts on Sunday and now it is Tuesday. The parts are still tacky. Is that normal? The humidity was <60% when sprayed then the parts were moved inside where the humidity is <40%. Link to comment https://success.kbs-coatings.com/topic/2876-dry-time/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 4, 20206 yr comment_5173 Yes, if you applied heavy coats, the parts could still be tacky. Please heat cycle the parts (120F and then 70F, repeat) and that will force the solvents out and cure the KBS Top Coater completely. Also, increase the air flow over the surface of the parts. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2876-dry-time/#findComment-5173 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
