Re-coating time for DiamondFinish Clear is very dependent on temperature and humidity. With that in mind, re-coating can be done once the first or consecutive coat is dry-to-touch and does not leave a fingerprint which is usually within 2-4 hours. When spraying, 10%-15% is normally adequate. Use KBS #1 Thinner (VOC Exempt) or Xylene ONLY.
https://success.kbs-coatings.com/topic/2771-polished-aluminum/#findComment-4969
So to repeat back, spray first coat, wait to dry to the touch before the second coat....usually 2-4 hours temp and humidity dependent. My shop conditions are 70 degrees with 25% humidity, so we should see dry to touch within the time specified. Thanks for your prompt reply and support.
I have never had a KBS Coating product disappoint me if applied correctly, I'm excited about coating the polished aluminum trim for our 1978 Ford Truck. This is a full restoration project with all the anodized aluminum trim removed, stripped of anodizing, polished to bright chrome look, cleaned and ready to coat with Diamond Clear. Thanks Again
https://success.kbs-coatings.com/topic/2771-polished-aluminum/#findComment-4970
