DaniusX Posted December 3, 2019 Report Share Posted December 3, 2019 Is it possible to heat cure the painted parts, off the car, with a heat gun? I've come across some heat guns that will go up to 1000 degrees Quote Link to comment https://success.kbs-coatings.com/topic/2723-heat-gun/ Share on other sites More sharing options...
KBS Coatings Posted December 4, 2019 Report Share Posted December 4, 2019 Yes, use a surface thermometer and the heat gun together to cure a piece that has been coated with XTC or XTC Primer. Get the surface to 300-350F and keep it there for 20-30 minutes. After that, let the piece come back to room temperature naturally (do not purposely cool it down). Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/2723-heat-gun/#findComment-4861 Share on other sites More sharing options...
DaniusX Posted December 4, 2019 Author Report Share Posted December 4, 2019 Didn't think to use a thermometer, good idea. An infrared thermometer should do the trick, as long as I don't measure the direct heat from the gun, unless I'm wrong? Quote Link to comment https://success.kbs-coatings.com/topic/2723-heat-gun/#findComment-4862 Share on other sites More sharing options...
KBS Coatings Posted December 4, 2019 Report Share Posted December 4, 2019 Yes, an infrared thermometer will work great and what we had in mind. Quote Link to comment https://success.kbs-coatings.com/topic/2723-heat-gun/#findComment-4863 Share on other sites More sharing options...
