Painting Geomet Rotors
I purchased a Motor Coater Kit to paint my brake calipers.  I just purchased new rotors that are Geomet coated: https://www.remmenbrakes.com/geomet-explained/
Is there any prep I need to do to the rotors other than Klean before painting?
Motor Coater is ideal for brake calipers.
For Rotors, grab the Rotor Restoration Kit which includes everything you need to remove the coating that is on there and to coat the rotors with a high heat rust preventative coating.
