Go ahead and strip out the kreem with MEK. Get all of the kreem out and then you can proceed to the KBS 3-Step Tank Sealing System. KBS Tank Sealer is not brittle and will not shatter delaminate if the tank is hit or dropped.
Your Success is Extremely Important To Us! We want your project to be a complete success so please be sure to read through carefully the following documents which will ensure your success using KBS Coatings.
Tank Sealer Directions: https://www.kbs-coatings.com/tank-sealer-directions.html
Tank Sealer: https://www.kbs-coatings.com/tank-sealer.html
Tank Sealer Kits: https://www.kbs-coatings.com/tank-sealers.html
Tank Sealer Application Videos: https://www.kbs-coatings.com/instructional-videos.html#ts
Tank Sealer Flow Chart: https://www.kbs-coatings.com/tank-sealer-flow-chart.html
Tank Sealer How-To Section: https://www.kbs-coatings.com/how-to-sealing-gas-tank.html
Tank Sealer Fix-It Guides found here: https://www.kbs-coatings.com/fix-it-guide-tank-sealer.html
Please let us know what size the tank is and we can recommend an exact kit for you to grab.
Thanks for contacting KBS Coatings.
