May 17, 20188 yr comment_4228 can I use top coat frame kit on my chassis and still use custom paint on my car body? will the custom paint bother the top coat system on my frame? Link to comment https://success.kbs-coatings.com/topic/2276-custom-paint/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 17, 20188 yr comment_4229 Yes, you can prep and coat your chassis with the Frame Coater Kit or the All-In-One Chassis Coater Kit. If the frame will see sunlight, it is best to use the All-In-One Chassis Coater Kit because it contains BlackTop which is a UV stable solid color top coat. You can coat over RustSeal with a custom body paint. There are three effective ways to topcoat RustSeal (with BlackTop, KBS Top Coater, KBS MAXX or other solid color top coat paints) effectively so that the coatings bond and fuse together. Please choose the one that works for your project. 1) Apply your top coat once the second or final coat of RustSeal is dry-to-the-touch and does not leave a fingerprint (usually 3-6 hours depending on temperature and humidity). 2) Let the second or final coat of RustSeal fully cure (at least 24 hours), scuff the RustSeal with 320 grit, then apply your top coat. 3) Let the second or final coat of RustSeal fully cure (at least 24 hours), dust the RustSeal with Fusion Self-Etching Primer, let the Fusion cure for 30 minutes, then apply your top coat. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2276-custom-paint/#findComment-4229 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
