March 9, 20179 yr comment_4034 I have a steel sign that is coated with your rust seal. Would an oil based enamel have an problems sticking to the seal coat? Link to comment https://success.kbs-coatings.com/topic/2180-oil-based-enamel-over-rust-seal/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
March 10, 20179 yr comment_4035 An oil based enamel will stick to cured RustSeal as long as you scuff the RustSeal with 300 grit or you spray a dust coat of Fusion Self-Etch Primer on first. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2180-oil-based-enamel-over-rust-seal/#findComment-4035 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
