March 5, 20179 yr comment_4029 I've got the KBS kit on order, arriving in a couple of days, to use on a motorcycle gas tank that sat for a couple of years and has rusted on the inside. The tank has an internal fuel pump and fuel strainer assembly consisting of a mix of plastic and metal parts. Is it safe to use the cleaner and rust remover on these parts, or not? And would it be safe to run the cleaner through the fuel pump? Many thanks. Link to comment https://success.kbs-coatings.com/topic/2177-safe-for-plastic-tank-parts-fuel-pump/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
March 6, 20179 yr comment_4030 Yes, you can use KBS Klean and RustBlast on the plastic and metal parts on the inside of the tank as neither of these product will harm plastic. Yes, you can run KBS Klean through the fuel pump. Please check out the Tank Sealer Directions and let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2177-safe-for-plastic-tank-parts-fuel-pump/#findComment-4030 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
March 6, 20179 yr Author comment_4031 Thank you. Link to comment https://success.kbs-coatings.com/topic/2177-safe-for-plastic-tank-parts-fuel-pump/#findComment-4031 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
