October 27, 201610 yr comment_3919 I recently used Diamond Finish Clear over an automotive base coat on a bicycle. I have a small area I would like to re-shoot the base coat and blend the DF Clear. What process is used to blend the clear topcoat? Link to comment https://success.kbs-coatings.com/topic/2136-df-spot-repair/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 27, 201610 yr comment_3920 Scuff the area with 800-1000 grit. Clean the area with KBS Klean. Then spray coats of DiamondFinish Clear thinned 30% with KBS #1 Thinner. DiamondFinish Clear can be cut and polished as a normal clear coat after 24 hours under normal conditions. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2136-df-spot-repair/#findComment-3920 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 27, 201610 yr Author comment_3921 I will follow your direction on my repair. I have the KBS Kleen and thinner so I am good there. It will be a week or two before I will be making the repair, I will post an update of my results. Thank you! Link to comment https://success.kbs-coatings.com/topic/2136-df-spot-repair/#findComment-3921 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
