July 19, 201610 yr comment_3811 Im going to be painting my motorcycle frame with one of your kits. After the rust seal I will be applying bondo. My question is do I need to apply a primer on top of the bondo surface before the Blacktop or will the Blacktop be ok over the bondo surface without a primer? Suggestions on a primer? Link to comment https://success.kbs-coatings.com/topic/2078-question-using-body-filler/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
July 19, 201610 yr comment_3812 Once the bondo cures, scuff slightly the bondo with 300 grit and then you can apply BlackTop. There is no need to apply a primer if you simply scuff the bondo before you apply BlackTop. Please check out the BlackTop Directions and let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2078-question-using-body-filler/#findComment-3812 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
