July 6, 201610 yr comment_3789 I will soon be coating a sub frame, and I was looking for best practices for flipping the frame over to paint the opposite side. Does the entire coating need to be applied in one shot, or can the top be coated, left to cure, then flipped over? Link to comment https://success.kbs-coatings.com/topic/2068-coating-of-a-sub-frame/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
July 6, 201610 yr comment_3790 You can coat one side (after it is prepped with KBS Klean and RustBlast) with RustSeal, let the RustSeal cure, and then flip over and paint the other side with RustSeal. Any time you coat a cured edge, simply slightly scuff with 300 grit to guarantee great adhesion. Please check out the RustSeal Directions and let us know if you have any questions. Link to comment https://success.kbs-coatings.com/topic/2068-coating-of-a-sub-frame/#findComment-3790 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
