Do I Have To Sandblast Frame?
You can either sandblast your frame or prep the frame with KBS Klean and RustBlast.
If you sandblast the frame, sandblast with clean sand and then blow off the sanding residue with clean air before applying a minimum of 2 thin, covering coats of RustSeal.
If you do not sandblast, clean the frame with KBS Klean and then etch the frame with RustBlast before applying a minimum of 2 thin, covering coats of RustSeal.
Please review the RustSeal Directions and let us know if you have any additional questions.
