February 12, 201610 yr comment_3524 I am planning on painting my frame in the spring. I am wanting a nice glossy finish. I was wondering what would be the best way to go about this? I was looking at the Blacktop with the DiamondFinish clear. Can it be Sprayed out of a HVLP gravity fed paint gun? Link to comment https://success.kbs-coatings.com/topic/1948-painting-my-frame/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
February 12, 201610 yr comment_3526 After you have prepped the frame using KBS Klean and RustBlast, apply 2 coats of RustSeal. Then you can apply BlackTop in Gloss Black and if desired, you can clear coat over the BlackTop with DiamondFinish Clear. The DiamondFinish Clear over the BlackTop will make it more glossy. There are three effective ways to topcoat RustSeal effectively so that the coatings bond & fuse together. 1) Apply your BlackTop once the second or final coat of RustSeal is dry-to-the-touch and does not leave a fingerprint (usually 3-10 hours depending on temperature and humidity). 2) Let the second or final coat of RustSeal fully cure (at least 24 hours), scuff the RustSeal with 300 grit, then apply BlackTop. 3) Let the second or final coat of RustSeal fully cure (at least 24 hours), dust the RustSeal with Fusion Self-Etching Primer, let the Fusion cure for 30 minutes, then apply BlackTop. You can feel free to choose the method that will work for you and do the same for putting the DiamondFinish Clear over BlackTop. Please review the RustSeal Directions, BlackTop Directions, and DiamondFinish Clear Directions and let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1948-painting-my-frame/#findComment-3526 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
