gf Posted January 29, 2016 Report Share Posted January 29, 2016 I'm restoring an older vehicle that has anodized aluminum wheels. The original coating is mostly gone, I'll be removing what's left with your KBS Strip. I'd like to keep the look as close to the original anodized finish, protected,, but not much of a shine. I thought maybe that I'd try your KBS Maxx clear flat. Any idea of how this might look? Any pictures you could share? Can KBS Maxx be used with a spray gun? If so, any specific instructions for use this way? Quote Link to comment https://success.kbs-coatings.com/topic/1934-kbs-maxx-on-aluminum-wheels/ Share on other sites More sharing options...
KBS Coatings Posted February 1, 2016 Report Share Posted February 1, 2016 The KBS MAXX Clear satin or flat would look great. For aluminum, scuff the wheels slightly to maximize adhesion. KBS MAXX Clear is designed to be sprayed and is incredibly durable. The KBS MAXX Clear Directions give you details on how to spray KBS MAXX Clear. For optimum results KBS MAXX Clear should be applied using spray equipment such as Conventional Electrostatic, Conventional suction spray gun, HVLP, Air Assisted Airless, or Airless. Brush or roller application should be used for touch up only. Conventional Electrostatic: Air Pressure: 40 - 60 psi Fluid Pressure: 15 -20 psi Cap: Medium Visc. Tip: 1.2 - 1.5 mm Conventional Spray: Air Pressure: 40 - 60 psi Fluid Pressure: 15 - 20 psi Cap: Medium Visc. Tip: 1.2 - 1.5 mm HVLP Spray: Air Pressure: 15 - 20 psi Fluid Pressure: 15 - 20 psi Cap: Medium Visc. Tip: 1.2 - 1.5 mm Air Assisted Airless: Air Pressure: 15:1 ratio pump or larger @ 80-100 psi Atomizing Air: Adjust as needed Cap: Medium Visc. Tip: 0.09 - 0.13” Airless: Pressure: 1500 psi minimum Tip: 0.09 - 0.11” Brush and Roll: Only recommend for touch up. Utilize a China bristle brush or high-density foam roller and reduce with Acetone. Note: The above parameters are to be used as a guideline only. Customer specific equipment may require a different set-up. Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/1934-kbs-maxx-on-aluminum-wheels/#findComment-3510 Share on other sites More sharing options...
