January 24, 201610 yr comment_3498 Can RustSeal be used as both a base coat and top coat? Or does it need to be top coated? Will be going on a frame that won't see direct UV rays. Also does it require any special activator, reducer, spray gun, etc...? Thanks Link to comment https://success.kbs-coatings.com/topic/1933-rustseal-used-a-base-coat-and-top-coat/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
January 24, 201610 yr comment_3499 If RustSeal is being used on a frame that does not see UV rays, there is no reason to put any paint over the RustSeal. You can leave RustSeal as your finish coat. RustSeal is a single component coating and does not require an activator. Spray pressure of 35-45 psi (250-330kpa) for siphon/pot guns and 25-35psi (170-250kpa) for gravity/top container guns. Thinning is not generally required but if needed 5%-10% is normally adequate. Use KBS #1 Thinner only which is a slow evaporating solvent. Generally, a 1.5 tip works well. Please check out the RustSeal Directions and let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1933-rustseal-used-a-base-coat-and-top-coat/#findComment-3499 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
