gf Posted January 11, 2016 Report Share Posted January 11, 2016 I'm removing the factory undercoating along both sides of the pinch welds on my VW. Pinch welds were bent in places where car was lifted improperly, undercoating peeling, surface rust where the undercoating has cracked. Can I apply the KBS Strip with a small brush so that it is applied in very small areas? What is the best method of neutralizing the surface afterwards to ensure that a new coat of paint won't be affected by any remaining stripper? Quote Link to comment https://success.kbs-coatings.com/topic/1926-applying-kbs-strip-with-brush/ Share on other sites More sharing options...
KBS Coatings Posted January 12, 2016 Report Share Posted January 12, 2016 Yes, you can use a brush to apply KBS Strip. Once the area has been stripped, clean the area with KBS Klean to ensure that additional paint will not be affected by the KBS Strip residue. Please check out the KBS Strip Directions and let us know if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/1926-applying-kbs-strip-with-brush/#findComment-3482 Share on other sites More sharing options...
