December 27, 201510 yr comment_3471 Can DiamondFinish Clear be applied over polished steel like a motorcycle gas tank and swing arm?? Link to comment https://success.kbs-coatings.com/topic/1921-clear-coat-over-polished-steel/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 27, 201510 yr comment_3472 Yes, you can clear coat over polished steel with DiamondFinish Clear. DiamondFInish Clear is formulated to be an ideal direct to metal clear coat. For best results, metals should be freshly polished or sanded to the finish required and then thoroughly cleaned with KBS Klean at a dilution rate of 10 to 1 with warm water (10% strength) with the use of a soft non-abrasive cleaning pad. Please check out the DiamondFinish Clear Directions and let is know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1921-clear-coat-over-polished-steel/#findComment-3472 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
