December 12, 201510 yr comment_3449 For a new truck that has no rust protection what do you recommend? Also doing a frame off restoration what do you recommend? Link to comment https://success.kbs-coatings.com/topic/1911-frame-off-restoration/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 12, 201510 yr comment_3452 Coating new truck frames so they do not rust is a very common application for our products. The Frame Coater Kit or the Large Frame Coater Kit are ideal for a truck where the frame does not see sunlight on a new truck or a frame off restoration. The All-In-One Kit is ideal for a truck where the frame does see sunlight on a new truck or a frame off restoration. The process is fairly simply: Clean the surface with KBS Klean, etch the surface with RustBlast, then paint 2 coats of RustSeal. If the frame will be exposed to sunlight, then you will topcoat with BlackTop. If the frame will not see sunlight, you will leave the RustSeal as your finish coat. Please check out the RustSeal Directions and the BlackTop Directions and let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1911-frame-off-restoration/#findComment-3452 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
