December 2, 201510 yr comment_3425 Can this product be sprayed? what quantity would be required to do a 1982 Chrysler Imperial that has been sitting in a warehouse for 11 years? Link to comment https://success.kbs-coatings.com/topic/1899-spraying-rustseal/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 2, 201510 yr comment_3427 Yes, RustSeal can be sprayed, brushed, or rolled. Spray pressure of 35-45 psi (250-330kpa) for siphon/pot guns and 25-35psi (170-250kpa) for gravity/top container guns. Thinning is not generally required but if needed 5%-10% is normally adequate. Use KBS #1 Thinner only which is a slow evaporating solvent. Do not reduce RustSeal with lacquer thinner. Also remember to clean your spray gun immediately after using RustSeal. You can find more information on Spraying RustSeal in our Spraying Guidelines. If you are looking to coat the frame, the Frame Coater Kit would be ideal for you. Please read through the RustSeal Directions and let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1899-spraying-rustseal/#findComment-3427 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
