November 7, 201511 yr comment_3370 If I brush on the Blacktop satin black on my frame and axles will I need to thin out the mix, or could I go straight out of the can? I have been a little bummed about reading a couple reviews on Summit Racing where I ordered the product today that two people said the paint looked blotchy and uneven after applying with a brush. They mentioned the Rust Seal satin black looked much better. Why would this happen? I do not want to go through all this work an have a blotchy looking frame. Please advise what I need to do in order to make this project turn out with great results. I also did not order any thinner, can I use any paint thinner brand if I need to thin out the Blacktop. Thank you. Link to comment https://success.kbs-coatings.com/topic/1876-brushing-on-blacktop-satin-black-on-frame-and-axles/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 8, 201511 yr comment_3372 The key to brushing BlackTop is not overworking the brush. When brushing BlackTop, do not overwork the brush as this can cause the BlackTop to cure too quickly possibly leaving visible brush marks. It is best to brush an area with BlackTop and move on immediately versus brushing an area over and over again. If you brush over an area over and over again forcing the solvents out, you run the risk of the brush marks not flowing out as well they are designed to flow out. If you want to, you can thin BlackTop 10% with KBS #1 Thinner to help the brush marks flow out. Also, please make sure you stir the BlackTop really well prior to using. All of the matting agents in the paint tend to softly settle to the bottom of the can and they need to be thoroughly incorporated back in for an even finish. Please be sure to check out the complete BlackTop Directions before starting your project and let us know if we can help you in any other way. Link to comment https://success.kbs-coatings.com/topic/1876-brushing-on-blacktop-satin-black-on-frame-and-axles/#findComment-3372 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 10, 201511 yr Author comment_3375 Thanks for the tips, one last question, If I do not have any KBS #1 thinner can I use just any paint thinner? Link to comment https://success.kbs-coatings.com/topic/1876-brushing-on-blacktop-satin-black-on-frame-and-axles/#findComment-3375 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 11, 201511 yr comment_3377 If you do not have any KBS #1 Thinner, you can use Xylene for thinning. Do not use anything other than Xylene or KBS #1 Thinner. Link to comment https://success.kbs-coatings.com/topic/1876-brushing-on-blacktop-satin-black-on-frame-and-axles/#findComment-3377 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 11, 201511 yr Author comment_3378 I have also read that it is not recommended to use the product directly out of the can. What do you recommend to use for a can? I have heard plastic is not a good option? Does it have to be a metal/glass container? Link to comment https://success.kbs-coatings.com/topic/1876-brushing-on-blacktop-satin-black-on-frame-and-axles/#findComment-3378 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
