Coat Copper Pipes
What products would you recommend for copper water pipes (hot and cold), natural gas iron pipes, and cast iron water heaters? Is there a coating that won't interfere with the heat coming from the radiator? I want paint and coat the pipes in my home.
RustSeal can be used on your copper and cast iron pipes. RustSeal will seal them up and RustSeal is thermally neutral.
Please make sure you clean the pipes with KBS Klean and and etch them with RustBlast first before you coat them.
RustSeal Directions.
