October 27, 201511 yr comment_3352 If i were to sandblast the area before i use Rustseal would i still need to use the RustBlast and KBS Klean on the sandblasted area before i put on rustseal? Link to comment https://success.kbs-coatings.com/topic/1867-prep-after-sandblasting/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 27, 201511 yr comment_3353 If you sandblast with fresh, clean sand, you would only need to blow off the sanding residue with clean air and make sure you only touch the surfaces with gloved hands. A sandblasted surface is an ideal surface for RustSeal adhesion. Please be sure to check out the RustSeal Flow Chart. If you have any additional questions, please do not hesitate to ask. Link to comment https://success.kbs-coatings.com/topic/1867-prep-after-sandblasting/#findComment-3353 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
