October 20, 201511 yr comment_3337 suggestions or maybe a recommended procedure to top coat with a sprayable truck bedliner? Link to comment https://success.kbs-coatings.com/topic/1861-bedliner-over-rustseal/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 20, 201511 yr comment_3341 Putting a top coat over RustSeal is very easy. There are three effective ways to topcoat RustSeal effectively so that the coatings bond & fuse together 1) Apply your truck bedliner once the second or final coat of RustSeal is dry-to-the-touch and does not leave a fingerprint (usually 3-10 hours depending on temperature and humidity). 2) Let the second or final coat of RustSeal fully cure (at least 24 hours), scuff the RustSeal with 300 grit, then apply your truck bedliner. 3) Let the second or final coat of RustSeal fully cure (at least 24 hours), dust the RustSeal with Fusion Self-Etching Primer, let the Fusion cure for 30 minutes, then apply your truck bedliner. You can feel free to choose the method that will work for you. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1861-bedliner-over-rustseal/#findComment-3341 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
