September 7, 201511 yr comment_3295 i used the rust seal about 2 years ago in my engine bay only.. ive recently started to work on the car again and removed all the undercoating and did some welding so some of the rust seal burned off.. my Q is how should i go about touching up those areas? scuff it up and use the cleaner and rust blast again? then just paint those small areas? as i wana order a kit to do the entire underside of the car since it has held up to great in the bay sofar. Link to comment https://success.kbs-coatings.com/topic/1846-burned-rustseal-off/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 7, 201511 yr comment_3296 You are on the right track. Scuff the areas with 320, then clean with KBS Klean before etching with RustBlast. After you have done that, you can apply 2 thin, covering coats of RustSeal. Please let us know if that answers your question and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1846-burned-rustseal-off/#findComment-3296 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
