August 27, 201511 yr comment_3265 Can RustSeal be sprayed by an hlvp air sprayer? Link to comment https://success.kbs-coatings.com/topic/1835-spraying-rustseal/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 27, 201511 yr comment_3266 Yes, you can absolutely spray RustSeal with an HVLP spray gun. You will want to use a spray pressure of 25-35psi (170-250kpa) at the gun for HVLP guns. Thinning is not generally required but if needed 5%-10% is normally adequate. Use KBS #1 Thinner only which is a slow evaporating solvent. Do not reduce RustSeal with lacquer thinner. Also remember to clean your spray gun immediately after using RustSeal. You can find more information on Spraying RustSeal in our Spraying Guidelines. Please let us know if that helps you and if you have any more additional questions. Link to comment https://success.kbs-coatings.com/topic/1835-spraying-rustseal/#findComment-3266 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
