August 20, 201511 yr comment_3255 I have some extremely rusty small machine parts that I want to rust blast. Do you have any recommendations for using an heated ultrasonic cleaner with this product? What should I set the temperature to? How long should I soak them? Should I dilute it? Link to comment https://success.kbs-coatings.com/topic/1829-ultrasonic-cleaner/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 20, 201511 yr comment_3256 Yes, you can use a heated ultrasonic cleaner with our prep products including KBS Klean and RustBlast. You can set the water temperature between 90F and 140F which will increase the effectiveness of the KBS Klean and RustBlast. You can soak your items for as long as it takes to get the job done. Overnight is not a problem at all. RustBlast should not be diluted. KBS Klean can be diluted 1 to 1 with water for your ultrasonic cleaner. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1829-ultrasonic-cleaner/#findComment-3256 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
