August 17, 201511 yr comment_3241 Can DiamondFinish Clear be applied over Rustoleum and similar oil based enamel products? Link to comment https://success.kbs-coatings.com/topic/1824-clear-over-rustoleum/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 17, 201511 yr comment_3245 Yes. If the other coating is 100% fully cured (water or solvent based) the DiamondFinish Clear can be applied over most other coatings. Clean the painted surface with KBS Klean and slight scuff any gloss finishes with 320 grit to get maximum adhesion. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1824-clear-over-rustoleum/#findComment-3245 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
