June 25, 201511 yr comment_3187 Hello, So I've used the KBS system on many motorcycle tanks with great success.... Now I have a Honda CBX tank that the PO had used RedKote over the rust.... Well you guessed it....the rust created a very tiny pin hole in the tank and the fuel fumes pushed out the paint into a 1cm bubble.... My question is: Will the KBS stripper remove the RedKote product..? Thanks, Erock Link to comment https://success.kbs-coatings.com/topic/1801-redkoteugh/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 25, 201511 yr comment_3188 Yes, the KBS Strip will get the redkote out and then you can proceed with the KBS 3-Step Tank Sealing System to seal up your tank. The Tank Sealer will seal up pinholes (tip of a pin). Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1801-redkoteugh/#findComment-3188 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 25, 201511 yr Author comment_3189 Thanks so much....!!! Going online now to order more product.. E Link to comment https://success.kbs-coatings.com/topic/1801-redkoteugh/#findComment-3189 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
