Benny Posted June 17, 2015 Report Share Posted June 17, 2015 Can you thin diamond clear with acetone? Quote Link to comment https://success.kbs-coatings.com/topic/1798-thin-diamondfinish-clear-with-acetone/ Share on other sites More sharing options...
KBS Coatings Posted June 17, 2015 Report Share Posted June 17, 2015 You can thin DiamondFinish Clear with acetone, but acetone flashes off very quickly making it not the ideal reducer, so we always recommend KBS #1 Thinner, which is a slower evaporating solvent blend. Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/1798-thin-diamondfinish-clear-with-acetone/#findComment-3180 Share on other sites More sharing options...
Sumo Posted February 28, 2022 Report Share Posted February 28, 2022 Is there a formula for thinning out the diamond finish clear? There are some kind of chart to reference? Quote Link to comment https://success.kbs-coatings.com/topic/1798-thin-diamondfinish-clear-with-acetone/#findComment-5436 Share on other sites More sharing options...
KBS Coatings Posted February 28, 2022 Report Share Posted February 28, 2022 When spraying, thin/reduce DiamondFinish Clear with KBS #1 Thinner or Xylene ONLY and 10%-15% is normally adequate. DiamondFinish Clear can be thinned up to 30%. Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/1798-thin-diamondfinish-clear-with-acetone/#findComment-5437 Share on other sites More sharing options...
Sumo Posted March 1, 2022 Report Share Posted March 1, 2022 I have found different answers on thinning finishes. Do you have a formula that you use? I’d like to know how much thinner would be needed for 32 ounce of diamond finish clear? For 10% for 20% and for 30% Quote Link to comment https://success.kbs-coatings.com/topic/1798-thin-diamondfinish-clear-with-acetone/#findComment-5438 Share on other sites More sharing options...
KBS Coatings Posted March 2, 2022 Report Share Posted March 2, 2022 This is what we use. 10% of 32oz is 3.2oz. 20% of 32oz is 6.4oz. 30% of 32oz is 9.6oz Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/1798-thin-diamondfinish-clear-with-acetone/#findComment-5440 Share on other sites More sharing options...
JustFishLures.com Posted October 13, 2023 Report Share Posted October 13, 2023 Can I thin it with Laquer thinner? Quote Link to comment https://success.kbs-coatings.com/topic/1798-thin-diamondfinish-clear-with-acetone/#findComment-5621 Share on other sites More sharing options...
KBS Coatings Posted October 13, 2023 Report Share Posted October 13, 2023 7 hours ago, JustFishLures.com said: Can I thin it with Laquer thinner? No, lacquer thinner is not a compatible reducer or thinner for DiamondFinish Clear. Please reduce or thin with KBS #1 Thinner or Xylene only. Quote Link to comment https://success.kbs-coatings.com/topic/1798-thin-diamondfinish-clear-with-acetone/#findComment-5622 Share on other sites More sharing options...
rom Posted September 17, 2024 Report Share Posted September 17, 2024 Cleaning Diamond finish with xylene to spray out of a cup gun. Will it daw the high gloss finish any? When thinning Diamond finish with xylene will it dull the high gloss finish any? Quote Link to comment https://success.kbs-coatings.com/topic/1798-thin-diamondfinish-clear-with-acetone/#findComment-6553 Share on other sites More sharing options...
rom Posted September 24, 2024 Report Share Posted September 24, 2024 When thinning Diamond finish high gloss with xylene. Will it dull the high gloss finish? Quote Link to comment https://success.kbs-coatings.com/topic/1798-thin-diamondfinish-clear-with-acetone/#findComment-6663 Share on other sites More sharing options...
KBS Coatings Posted September 24, 2024 Report Share Posted September 24, 2024 Cleaning Diamond finish with xylene to spray out of a cup gun. Will it daw the high gloss finish any? -- No. Xylene will not affect the gloss level of DiamondFinish Clear. When thinning Diamond finish with xylene will it dull the high gloss finish any? -- No. Xylene will not affect the gloss level of DiamondFinish Clear. When thinning Diamond finish high gloss with xylene. Will it dull the high gloss finish? -- No. Xylene will not affect the gloss level of DiamondFinish Clear. Quote Link to comment https://success.kbs-coatings.com/topic/1798-thin-diamondfinish-clear-with-acetone/#findComment-6664 Share on other sites More sharing options...
