The inside of my tank still looks a bit rusty after cleaning and rustblast. I kept the inside of the tank wet with the rustblast for about an hour, turning and shaking it every 5 minutes or so. Drained it out and washed out the tank and dried it well with a heat gun. Examining what I can see of the inside of the tank I can still see areas that look a bit red with rust. Its not a lot but more than a little.  The photo shows a bit of it, there are similar but larger areas inside the tank.
Is this OK. Do I just proceed with the sealer or should I re-use the rust blast again or get some more?
thanks.
It looks like the loose flaky rust has been removed (happened during the KBS Klean step) and the surface rust has been etched really well with the RustBlast. Because your time frames for allowing the RustBlast to etch the inside of the tank are correct, please proceed with confidence to the Tank Sealer step.
If you have any additional questions, please feel free to contact us.
