Jump to content
Recently, I purchased the KBS Cycle Sealing kit. I have applied KBS Klean and RustBlast as directed to a rusty motorcycle gas tank. The products removed approximately 85% of the deposits from the metal. However, two 2-3" strips of rust still remain in the bottom of the tank after repeated applications. Would applying the seal now allow it to properly adhere over these rusty areas, or should these significantly rusted areas be treated further before the sealant is applied?
Link to comment
https://success.kbs-coatings.com/topic/1784-rust-remains-in-tank/
Share on other sites
This is a great question and we can assist you. As long as the loose flaky rust has been removed and the entire tank (including rusty areas) have been etched well (30 minutes minimum on each side) with RustBlast, you can proceed on to the Tank Sealer step. TheĀ Tank Sealer is more than capable of adhering to some surface corrosion.
Thank you for choosing KBS Coatings!
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
Loading...
  • Create New...
