May 21, 201511 yr comment_3156 Recently, I purchased the KBS Cycle Sealing kit. I have applied KBS Klean and RustBlast as directed to a rusty motorcycle gas tank. The products removed approximately 85% of the deposits from the metal. However, two 2-3" strips of rust still remain in the bottom of the tank after repeated applications. Would applying the seal now allow it to properly adhere over these rusty areas, or should these significantly rusted areas be treated further before the sealant is applied? Link to comment https://success.kbs-coatings.com/topic/1784-rust-remains-in-tank/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 21, 201511 yr comment_3157 This is a great question and we can assist you. As long as the loose flaky rust has been removed and the entire tank (including rusty areas) have been etched well (30 minutes minimum on each side) with RustBlast, you can proceed on to the Tank Sealer step. The Tank Sealer is more than capable of adhering to some surface corrosion. Please let us know if that helps and if you have any additional questions. Thank you for choosing KBS Coatings! Link to comment https://success.kbs-coatings.com/topic/1784-rust-remains-in-tank/#findComment-3157 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
