Epoxy primer over rust seal
Can I use epoxy primer over rust seal? It is a urithane epoxy primer. If I can what is the best method for adhesion.
There are three effective ways to top coat RustSeal with an epoxy primer effectively so that the coatings bond & fuse together.
1) Apply your epoxy primer once the second or final coat of RustSeal is dry-to-the-touch and does not leave a fingerprint (usually 3-10 hours depending on temperature and humidity).
2) Let the second or final coat of RustSeal fully cure (at least 24 hours), scuff the RustSeal with 300 grit, then apply your epoxy primer.
3) Let the second or final coat of RustSeal fully cure (at least 24 hours), dust the RustSeal with Fusion Self-Etching Primer, let the Fusion cure for 30 minutes, then apply your epoxy primer.
You can feel free to choose the method that will work for you.
  • Author
I assume this step is the better choice because of a better chemical bond??
  • 3 weeks later...
Yes, the method you asked about does give you a chemical bond and is ideal. However, the other 2 methods work very well as well.
  • 11 years later...
Updated for 2026: The three ways to topcoat RustSeal remain the same, with two updated numbers.
1) Apply your primer or topcoat once the final coat of RustSeal is dry to the touch and does not leave a fingerprint, usually 3-6 hours depending on temperature and humidity.
2) Let RustSeal fully cure at least 24 hours, scuff with 320 grit, then apply your primer or topcoat.
3) Let RustSeal fully cure, then apply a dust coat of Fusion Self-Etch Primer before your topcoat.
Full directions: https://kbs-coatings.com/rustseal-directions
Fusion Self-Etch Primer: https://kbs-coatings.com/fusion-self-etch-primer
