Aluminum boat
Will this coating work on a 22' alumin. boat? The product that is used presently by most alumin. boat users is Sharkhide.
I want to be able to coat just the sides of the boat.
How long will the coating last?
post-2284-0-31376800-1424457156_thumb.jp
Yes, the DiamondFinish Clear works great on aluminum boats and is a very common application. For marine applications, 3 or more coats are always best.
The longevity of the DiamondFinish Clear should be 5-10 years as it is a permanent type coating. DiamondFinish Clear can be cut and polished as a normal ClearCoat after 24 hours under normal conditions.
Please check out the DiamondFinish Clear directions HERE.
Please let us know if that helps and if you have any additional questions. Thank you for contacting KBS Coatings!
